Robert Wilson
Propcalc give a 12*9 so your 13*8 is about right (1" greater diameter but 1" more diameter is "good")
Your 2 blade is too big diameter as there is not enough clearance as you found. Pitch will not be 2", probably more like 7 or 8.
Your displacement is I think wrong as the figure should be kgs rather than lbs.
The prop size is calculated to achieve close to maximum revs and hull speed at the same time, so you should get around 6 knots at revs above about 3300 (you are a bit short on power for the displacement). This will allow you to cruise at 50% power (or 70% revs - about 2500) at 5 knots.
I couldn't log on to Propcalc, but I did revise my displacement to 7560lbs.
As expected it gives a noticable difference in HP required (17), and prop dimensions (3 blade 11.9" x 6.7" pitch)
I note your comments "a bit short on power for displacement", but I'm comparing "same power train + gearbox" with the new prop.
Very odd, and most disappointing/worrying.
Thanks Tranona
