Tranona
Blocked exhaust run is unusual but not impossible, so first thing is to remove the exhaust elbow attached to the engine. It is the crook shaped bit that connects to the exhaust piping. It will not be easy to remove as it has been on there for years. However it is this bit that gets blocked and even a small hole in the middle will allow the engine to rev to maximum in neutral because it is not producing any power like that. once you have the exhaust hose off you may be able to get a finger (with a glove on -oooer!) up the pipe to asses how coked up it is. Regrettably there is no alternative to removing and cleaning, but hopefully it will not be so bad as to fall apart as you poke the muck out.
Not all as bad as it sounds compared with other things you have done on your boat.
