Are you sure? Appears to have a peak and throat halliard, so I think gaff.Gunter porn at that.
Definitely gaff rigged. In its narrowest (most pedantic?) definition a gunter rig would have a tensioned wire strop up the back of the mast to which the gaff is attached. This allows the gaff to slide up and down for reefing without falling away from the mast. Whether the simplified rig seen on small dinghies such as Herons and Mirrors can truly be called a gunter is an argument I'll leave to the pedants.Are you sure? Appears to have a peak and throat halliard, so I think gaff.
Not that I'm pedantic!
Maybe. The only gunter boat I have sailed was the Yare and Bute ODs on the Broads which we called gunter because the gaff was high and close to the mast, as in this boat, so for me a gunter rig is just a very high gaff, rather than having any particular equipment.Definitely gaff rigged. In its narrowest (most pedantic?) definition a gunter rig would have a tensioned wire strop up the back of the mast to which the gaff is attached. This allows the gaff to slide up and down for reefing without falling away from the mast. Whether the simplified rig seen on small dinghies such as Herons and Mirrors can truly be called a gunter is an argument I'll leave to the pedants.
Anyway, whatever the nomenclature of the rig, that's a very nice boat.
