Refueler
The three pontoons to left in channel are now across the channel creating a floating bridge from one side to other. This makes electrical supply much easier and access to boats from both banks.
But the pontoons are 2nd hand and quite old. The woodwork being plain untreated and was not so good in various places when I bought. But price was good ...
I have new grooved treated wood specially for balcony's pontoons etc ready with main beams ... but problem is the pontoons are metal framed with closed metal pipe flotation. Very heavy. Weather has created soft ground and would not be possible to get suitable truck to lift as when they were lifted in ...
The problem of construction :
The grooved boards - same as many UK pontoons as Latvia actually exports same to UK etc for pontoons !! - are screwed to main beams set into metal longitudinal U frames. Take off the boards - no problem .. but then need to have footing to stand and remove the main beams ... standing on the flotation pipes is not advised ...
So how to remove all and leave metal frame .. then fit the new main beams ? They are 6m long and 20cm x 20cm sqaure for sides and 15 x 20 centre line beams ....
One suggestion made by a pal ... wait till winter and they are frozen in ... the ice will be thick enough to walk and work on ... mmmmmmmm not exactly my idea of fun !
I am considering towing each one in turn to the nearest slipway and then the truck can lift and bring them home to stand on the ground.
But if there is a way to do while on water - that would be preferred...... my truck crane can lift the beams OK .. so maybe put pontoons back along the bank ??
