Ply - non boaty.
KevO
10 Aug 2011
Falmouth
Non boaty but prob best place for responses šŸ˜ Sonā€™s new house has a large shed in garden on a paving slabbed area with what looks like reasonable run off. All sides and roof seem very sound although a fresh coat of preservative will work wonders. Base is blo*dy chip board on 2x3ā€ stringers which needs replacing. Plan is to lift shed off, rebuild a base on new stringers and remount shed etc. My ply of choice would have been 15 or 18 mm marine ply but expect he might baulk at cost - his first house and he is proud as punch and wants to do (pay) for everything himself although Dad labour and advice is always welcome. So, is marine ply overkill here? Would WBP/exterior ply from x supplier do the job if edges sealed with ā€˜poxy or similar? Is all WBP from usual ā€˜ townā€™ outlets gonna be a crap waste of time and money? Thoughts?
KevinV
12 Oct 2021
Sheds go awful floppy without their bases, and are surprisingly heavy - if you can avoid lifting I definitely would, at all costs.
DownWest
25 Dec 2007
S.W. France
Couple of us are building boats from exterior ply. 10mm standard sheet is around 60 euro. Not being too trusting, I boiled a bit and it is fine. Really surprising, no voids at all!
Peeps say, that economising on ply is a bad idea, but depends on what you can find. Good 'marine' here is well over three times the price.
Norman_E
15 Mar 2005
East Sussex.
WBP ply is quite suitable for a shed floor. I have bought WBP ply from both DIY stores and builders merchants in the past and there does not seem to be much difference, As said above the shed is likely to be far too heavy to lift if its a big one.
Supertramp
18 Jul 2020
Halifax
Exterior ply is good but avoid it getting continuously wet. Mount it on pressure treated timber - it's the bits in contact with the ground that stay wet. Even better to keep the wood off the ground with bricks/breeze blocks. Make sure it's anchored unless very sheltered. Marine ply is overkill. Unless the rest of the shed is marine ply......
Blueboatman
10 Jul 2005
The main thing is airflow underneath
So stringers laid 90deg across treated timbers on the slab/blocks would be ideal for avoiding rot in flooring .
(Skinners sheds do just that and they last noticeably longer than stuff from the diy outlets )
You could use t and g boards or old floorboards too instead of osb/wbp plywood
Boathook
5 Oct 2001
Surrey & boat in Dorset.
Both my sheds have tongue and groove floors mounted on stringers at right angles. I mounted the sheds on more stringers that in turn were on brick piles to make it all level. One shed is nearly 20 years old and the other 2 years old. The floor on the older one seems to be lasting better than the sides so far.
Rappey
13 Dec 2019
My shed is at least 35 yrs old, sat on bricks and has floorboards with 4-5mm gaps aiding ventilation.
Only thing ive had to do is refelt it twice so far, and use a wooden support pole inside to stop roof sag
Jim@sea
12 Feb 2010
Glasson Dock
If you are using plywood for the base why not get a small sheet of Visqueen and fix it all round the plywood with drawing pins. That would add 20+ years to the life span.
Rappey
13 Dec 2019
Sheds are fairly flexible so how about using a jack, lift and slide another pressure treated timber under the floor .
Im not sure if your suggesting the chipboard also needs replacing.
Why not use what ever sheet material is cheapest as it should not be getting wet . Sterling board /osb is quite common for shed floors.
Phenolic birch ply is by far the best ply ive ever used. Ive some offcuts in the garden that have had 8 years of weather on them and other than gone grey its still not gone soft.
38mess
9 Apr 2019
All over the shop
I used exterior ply on part of my boat deck. I epoxied over it and 5 years down the line it is still fine. It gets wet occasionally. Marine ply is Ā£90 a sheet in Travis Perkins, and it's pot luck what quality you get.
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
Travis Perkins are another crap ply supplier and the 1088 mark now means nothing as it is used by any number of oriental ply manufacturers. I still reckon Buildbase can't be beaten, but then once encased in epoxy it doesn't really matter unless it is already delaminating when bought from the shop like the RGB stuff.
38mess
9 Apr 2019
All over the shop
A few years ago I had 3 sheets of 18mm marine ply from Travis Perkins to make seats for my boat. We threw the off cuts under the boat and the next day they were like Bananas totally delaminated.
It took almost 3 months to get them to agree a refund, and then they wanted to send another 3 sheets. But I got the replacements from browns in Bristol. 10 years later they are still sound.
