Ships_Cat
Because of the heavy conditions and steep, short wavelength seas we often encounter in our home waters I take an interest in information I find on the pitching performance of yachts. I recently came across this forum post http://www.macnaughtongroup.com/_disc5/0000025b.htm from MacNaughton Yacht Designs which I found very interesting (others may find the same).
Our own cruising boat is designed along the lines he outlines with a low ballast ratio (less than 30%) and we carry alot of weight in the bow for the reasons outlined in the post (normally 2x 60lb anchors, 1x 40 lb anchor, approx 105 m 10mm chain, 110m 20mm warp, assorted mooring lines in an approx 10 tonne, when empty, fin keeled, semi-balanced rudder boat).
As he says the results can vary depending on the boat. We find it works well in our own boat which is quite fine forward with no flare and alot of beam aft to get displacement and form stability, and can sail closehauled at hull speed into steep 30-40 knot rip type seas (and motor with 50 hp at 5-6 knots into similar, vs 7 knot cruise in smooth water). We have never experienced rhythmic pitching although we have non rhythmically pitched to a stop motoring into very steep standing waves.
I would be interested in any real life experiences along the lines I have set out with various hull shapes and weight distributions in yachts that others may like to pass on.
Thanks in advance.
John
Thanks in advance.
John
