maxi77
I can't see the problem.
If I really need a pee I just go home.
Why wait, it warms up the wet suit.
I was thinking the same thing. Go to your GP and ask for a PSA blood test, no fingers up the bum required.
On the other hand if that is what you want, phone 09000 GSPOT
[Later] By the way, if you put your feet on a small platform, or just sit with your feet on tiptoes, it increases the flow from both orifices.
There's too many postings here from those, ostensibly, joking about potential prostate problems and not bothering/caring to see their GP?
I hope to Murgatroyd they were all joking......?
Surely Comfort would be more appropriate?Some ( most ??) laundry product bottles do not have a wide enough top.
Try before you buy.
Sainbury's Super Concentrate biological liquid bottles have an adequately wide top.
( I now keep one in the car)
Relying on the PSA test is apparently not wholly satisfactory.
Read this article (it may be slow to load)
I think the suggestion was not that the PSA test was at fault rather that it was just an indicator to show further testing was required before starting treatment, which may cause more harm than good. First you need to know there is cancer, then what kind. I think you will find in the UK that the PSA test is purely used for screening and is only taken as an indicator that further exploration is needed.
Probably best with the cornflakes container right next to the toilet seat!![]()
I read a while ago that the commonest cause of MOB fatalities was peeing over the side and falling out of the boat.
I thought that was what I was saying.
I certainly didn't say that you should avoid having the PSA tested.
I heard that the RNLI called these casualties LIFO (Lifejacket Inflated, Flies Open)
Dear Commander Stilleke,
Thank you for your prompt and informative reply.
Regards,
bbg
"Stilleke, Steven CDR" <email address@uscg.mil>
Sent by: address@uscg.mil
03.10.2007 20:08
To
bbg
cc
Subject
RE: Coast Guard Web Mail: Acronym FDFO
Mr. bbg,
The Coast Guard does NOT use such an acronym. Although we do know that people
have fallen overboard in this manner, it is not something on which we keep
statistics.
Regard,
Commander Steven Stilleke
U.S. Coast Guard
Office of Search & Rescue
Washington, DC
-----Original Message-----
Sent: Wednesday, October 03, 2007 1:24 AM
To: Stilleke, Steven CDR
Subject: Coast Guard Web Mail: Acronym FDFO
Category: Search and Rescue
Message:
There is a rumor in the boating community that the USCG uses the acronym FDFO
for boaters who are "Found Drowned, Fly Open". Used for people who drowned
after falling off their boats while urinating.
I have two questions:
First, does the USCG use this acronym
Second, how many people are found or assumed to have drowned for this reason?
Thanks and regards,
bbg
I've had the same symptons now for 10 years. Being in my early 40s never considered it would be a prostrate problem. Does make me wonder if I should see GP.
Tried everything to see if I could fully empty bladder sitting down, but to no avail.
I have a cut down plastic milk bottle. (1 litre type, square cross section about 20cm high?). Cut it with scissors so as to not leave sharp bits! Cut away part of the top and side leaving the handle intact, making the hole big enough for your own needs.
Advantages include: deep enough to not get splash back; Covered in enough to use in rough weather; sufficient volume for even a big pee; easily obtainable replacements; low cost; disposable (as if an empty milk bottle - which it is); translucent so that contents can be seen; doesn't break - so it can bounce about the cockpit if needed.
Using the jabsco I kneel. There's just space and aim is far better at point blank than standing. Getting out of oilies to pee is too much work. There are handles behind the loo, but holding them while standing means steadying the upper body, while feet on the ground fixes the lower legs, this leaves the heaviest part (torso, hips) to swing about between these two fixed points. That results in erratic aim.
All of this is modified by circumcision or not. Typically circumcised males have better aim, with a tighter flow stream. Having a sprinkler nozzle on the end doesn't help.
I often do this, but it's annoying when your todger dangles in the water.
