Ado
I'm aware of the suitability of the Yamaha 9.9s, I've used the for over 20 years. However your assessment of 40% less power astern is of great help, thank you. Could you please reply with the pitch and number blades on your props.
Remember that best pitch depends on gearing. I believe the Yamaha's are geared lower.
My PDQ is about 8600 pounds and will motor ~ 7.8 knots. Should be well about 6 knots.
The stopping power of the twin Yamahas compared to the stopping power of a Tahatsu is considerable, IME, since I have had both. Like 40% different. Other that pitch, rpm, and diameter, is the fact that Yamaha props are designed to vent the exhaust away from the prop in reverse, greatly reducing ventilation. This is perhaps the thing that sets the Yamaha motors apart in reverse.
Even given the gearing, 2.95, that seems a tad coarse. 9.25/12 x 5500/2.95 x60 /6000 (pitch in ft x prop rpm x mins per hour /ft per mile) gives over 14kn. Allowing for slip, it’s a bit coarse.11.5 dia x 9.25 pitch, 3 blade is the spare I have. They also vary some by year. But remember that the Yamaha props are GEARED LOWER than the other motors, that are just dinghy motors with longer legs. Lower rpm = more static thrust with the right pitch. And the Yamaha hubs have an exhaust reverser in them.
