LONG_KEELER
I had a petrol leak this year and have decided to renew all the fuel lines . The hose clips are the type you squeeze with your fingers and slide off down the hose. The leak was caused by one of these clips cutting into the hose. Instead of using the metal clips, I thought of using cable ties of a suitable size to avoid cutting in. Is there any reason for hose clips to be metal ? Perhaps to do with heat from the engine ? There is not much room to use jubilee clips. TIA
