sailaboutvic
I hear inflatable rudder which you can hang behind the rudder , are freely given out by the Portuguese CG ,
so people can test them out
there already is an organisation doing that ,, i think on a monthly basis , how comprehensive it is i dont know , that is one thing that those on the ground can better judge .Too true
We often get a bad press as non essential amateur boaty enthusiasts wanting finance from the general purse. So it's difficult to see where the money will come from unless Orcas start taking people from beaches or interfere with local pleasure boats. It would be nice to see a chart marked where incidents have taken place which might help to lessen the odds. Otherwise I think we are on our own mate!. Collision bulkheads close to the rudder area might help.
i would think / hope a more intelligent approach would / could / should be taken , where eg if the dummy is being attacked then it should be retrieved straight away ,, i cant i,mmagine any reason for leaving it in for them to play with . let is remember that there are countless documented incidents of orcas interacting with humans but none ( few ) of there being attacks .A dummy in the water for them to toss around may train them to do the same with any human who ends up in the water.
Unfortunately not always up to date and I'm not convinced it's complete. But it's currently the best resource available.One here orca iberica
I wonder why they didn't bite the dinghy?More from @vitrodfull. "The dinghy helped a lot. I would suggest to use two or three fenders on the water to keep them busy, if there is no dinghy."
It is not on their menuI wonder why they didn't bite the dinghy?
I would like to see the damageThey described it as "damaged" after the 2.5 hour event.
I can't see my long fin Nic39 going astern in a straightish line for two hours . More likely in ever decreasing circlesWhile it is too early to know if 'slow reverse' will prove to be a reliable and lasting solution it is quite possible to now move backwards from solution to speculate why it might work. Superman is laid low by kryptonite, darleks can't go up stairs, and orcas seem not to be able to swim backwards. A yacht motoring in reverse has formidable defence from a pursuing orca since the propellor is now ahead of the rudder and the rudder presents a much less convenient edge to bite. A deep spade rudder may be more vulnerable but even here it has some protection from the keel which must be negotiated first. Of course, even if successful it might prove a temporary solution as orcas learn new methods of attack but, for the moment, I think it has promise.
I can't see my long fin Nic39 going astern in a straightish line for two hours . More likely in ever decreasing circles. But maybe that will confuse them and they'll just go away.
Not that I will be there but some Nic39 owners of my acquaintance might be.
To tender ?It is not on their menu
I watch more youtube than tv. It's built into the tv and it's easy to use so I browse a lot of content. I've no idea what the video wasand it was a clip within a video.i have not seen that , do you have a name ?
Not me. Ive no prob with them being called a-holes, i'd call teenage neds the same, even if their species name is humanI think your 'reality' would be a wee bit different had it happened to you.
