ducked
I'd think it might require water sloshing forward to force the lower buoyancy bows down, but I don't really know.There is more buoyancy in the wide stern, the keel (and centre of mass) is in the middle, and there is less buoyancy in the bow. Without any additional ballast (in the form of tons of seawater) the boat floats level due to the distribution of tanks, engine etc.
As the water starts to come in, it will head for the deepest part of the bilge, which in most AWBs is where the keel bolts are, regardless of doors etc, it is going through the channels and holes in the grid structure as it is designed to do. The design assumes any water ingress, regardless of entry point, must flow to the deepest point of the bilge to allow the bilge pumps to do their stuff.
So water initially accumulates in the bilge to allow the bilge pumps to pump it out (that is why the bilge pump pick-ups are located there).
As the volume of water increases, and the bilge pumps fail to remove it, the bow (with less buoyancy) sinks more than the stern. The boat is no longer level, and the water shifts towards the bow as it is now lower than the bilge, so the boat sinks nose-first due to the buoyancy difference between bow and stern.
... that is how I would envisage the mechanics of a bow first sinking.
Requires an experiment
Cant be me though.
My boat isnt modern enough to have such an assymetric distribution of buoyancy
Does have the vulnerable spade rudder, but at least it will probably sink on an even keel
