Ooops, should have worn a bit more...
Wow how'd you get your front canopy folded away so neat?! Each time we fold ours back we always seem to end up shoving loads of loose ends up into a messy bunch and hoping it all stays in place - sure there must be some proper way to do it!
As you push the upper canopy back, lift the middle bar, and allow the canvas to fall rearwards between the bar and the arch.
Pull out one side to make a triangular corner, then fold back in and roll up one side as tightly as you can, tuck it under the cover and attach a couple of poppers.
Move to the other side, and repeat the corner folding thing, roll up that side, attach a couple more cover poppers. Tuck in any stray bits (straps etc) then roll up the middle bit of the sausage and do up all the poppers.
Easy!
(once you've done it about 30 times or so)
Nice one, thanks for the tips - sounds simple (well until I've got arms full of canvas and poppers!). Will print this off and give it a go at the weekend.
Thanks again cheers, Rich
