Momac
The desiccant isn't consumed so I don't expect the dissolved solids to be highClarity is not a reliable indicator of dissolved minerals. A saturated solution of salt will look just the same as drinking water, unless you do tests to measure properties like refractive index. If water has been in contact with zeolites it will almost certainly have carried some mineral content from them; zeolites are pretty reactive by mineral standards, and offer a vast surface area on which reactions can take place. The latter property is, of course, why they are efficient desiccants. But I wouldn't be at all surprised if the water had a high level of dissolved solids - as much if not more than tap water.
It might be ok - I don't know the exact mechanism of a desiccant dehumidifier - but I certainly wouldn't take the chance.
In any case if the dissolved solids are Zeolite isn't that better than the alternative of lime in tap water as far as engine coolant is concerned?
