Old Style Navigation Warning
rotrax
17 Dec 2010
South Oxon and Littlehampton.
AFAIK, the 'bale of hay' was hung over the centre span of a bridge arch to tell those coming upstream which arch to use in poor light conditions.
Another bale might be used on an arch for downstream traffic, so separating them.
From my River and Canal boating days.
Snowgoose-1
2 Jun 2015
I'm just about to hoist a traffic cone on the car pointing south to warn everyone on the M25 of the impending doom tomorrow.
kwb78
8 Jun 2005
Is this the wobbly bridge that needed to be adjusted so not to upset landlubbers?
Yes, but there was a good reason behind it. The phenomenon that caused it to wobble was unknown prior to the opening of that bridge. Resonance was known to happen with certain circumstances on bridges (eg troops being told to break march and walk), but the resonance on the millennium bridge happened with people just walking independently over it.
What happened was a result of the geometry of the bridge causing the resonant frequency to fall within the range of human walking pace. As people walk they transfer their weight from one foot to the other. This causes an alternating sideways force on the bridge from the feet. This is small, and even though they are not stepping in sync it is not fully cancelled out, and when many people are walking at the same time, there is a resultant force which deflects the bridge sideways. When the bridge returns to its normal position, this imparts a small and imperceptible force on the feet of the people walking.
Although they are not aware of it, people subtly adjust their gait to balance in response to this force, and because it is applying to everyone simultaneously it nudges them into walking more in sync, which caused a positive feedback loop, amplifying the movement of the bridge until it could be seen and felt to wobble.
The fix was to add damping for the sideways movement to reduce the movement and modify the resonant frequency so it was less affected.
Fr J Hackett
26 Dec 2001
Saou
Well I never! Our company secretary my boss for a very short time :eek: had an office very close to it so I got to test it out quite often.
Bristolfashion
19 May 2018
The current "recreational users guide" refers to a bale of straw. It's still current practice. Not the worst thing to hit!
rotrax
17 Dec 2010
The bale rarely hangs below the bridge arch-it would hit passing vessels and would soon be destroyed. It is above the arch, supported to its rear by the bridge structure.
You dont want to hit that, straw bale cushioning the blow or not...................................... :cool:
