warrenmarkus1
I have recently got a old Johnson 3.0hp twin cylinder outboard which was a non runner.
I have got it to start, and run, but am having problems getting it to idle, and rev properly.
The plugs are new and set to 0.5mm, as are the points.
Fuel mix is 20:1 as written on the tank. There is a spark on both cylinders, and both plugs are firing. The engine seems to run better with the intake silencer not fitted. The plugs are blackish-too much fuel?
Does anyone know the settings for carb mixture screws, or the resistance values (or other method) to check the magneto coils?
One coil has a green coloured plastic housing, while the other is brown, and I am not too sure if this has a bearing
