Oil pressure low
Jelly
5 Jan 2004
Essex, Crouch.
Before I get frog-marched to the bank by my friendly local Volvo dealer, I was wondering if anyone had any idea...
One of my TAMD31's has just started to drop its oil pressure. It runs at just over 60psi when under load but then drops to about 20psi when idling, setting the oil pressure warning light off. This is a new development, which coincides with a new but very small oil leak (still cant find where its coming from, but there's a persistent oily film on the bilge water).
Any thoughts gratefully appreciated...
studgies
7 Jul 2003
Southampton
www.marvinmarine.co.uk
be sure it is not the sensor that is knackered and that the relief valve is not knackered seems to be a common fault with the tamd engines, there were many posts about this very subject a few months back but they were also covering the engines habbit of dumping all it's oil through the breather when running hard!!
Dave_Seager
4 Jul 2001
Weybridge, UK
www.seagers.org.uk
I would check the pressure sender first as I had similar problems with a car some years ago.
The diaphragm in the sender unit can split which causes it to malfunction and also leak a very small amount of oil. There is normally a small hole in the switch casing to expose the outside of the diaphragm to atmospheric pressure. If there is any oil showing there it is almost certain that the diaphragm has split.
<hr width=100% size=1>Dave Seager
Weybridge UK
RIN
2 Mar 2003
West Midlands
I would swap the senders over to see if the sender was at fault - but first change the oil filter - I had a similar problem on one of my KAD32s which cleared when I changed the filter
<hr width=100% size=1>No! No! - I mean the other Starboard
Its_Only_Money
11 Aug 2004
Leicester - boat on Hamble
I'd endorse RIN, swapping the senders is nearly free, if the problem stays with one engine I'd also be tempted to change the instrument heads over temporarily, if you still have low pressure then it has to be internal to the engine, either the pressure relief valve sticking open, or possibly the filter bypass (most engines have a bypass so that if the oil filter clogs you will still get some oil flow), but you'll need an engineer by that stage.
I'd do the sender and instrument change prior to changing the oil and filter but that might just be a personal preference....
<hr width=100% size=1>Rgds
Simon
Its Only Money
Fairline Sprint
Solent-based
Jelly
5 Jan 2004
Essex, Crouch.
Engine hours are 900 (15yrs old). Engines have been fastidiously maintained by the previous owner. I've done 50 hrs this season (I bought it in May of this yr).
Regarding the oil filter, are you refering to the leak or the lack of oil pressure?
Many thanks,
Mike.
RIN
2 Mar 2003
West Midlands
Mike
I had the low oil pressure problem after 40 hours. I was away cruising at the time. The trouble finding section in the volvo manual only listed two possible causes for low oil pressure - low oil level or blocked filter - oil level was ok so I changed the oil filter and all has been ok - now at 90 hours. I had no leaks.
Hope you get it sorted
Richard
motoguzzi
23 Jan 2010
hi iv e got another oil related gremlin in one of my 31s . between 2800 and 3000 rpm the oil alarm sounds and then clears if you lower or raise the rpm . it only occurs under load. there are no oil leaks and the pressure is fine.Ive carried out a recent service so all oil and filters are clean . can any one help ?
