Mexican
Is it worth putting oil flush in engine prior to oil changes? Comments?
If the oil is changed regularly I can't see what an additive can do to help. On a slightly different subject I wonder whether it is necessary to change the filter every year. I put new oil in each winter , after about 80 hours use of my Volvo diesel and always change the filter as well. But it is a messy job and I have often thought that a filter should last for a couple of seasons at least. Any thoughts anyone? Apologies for the thread drift by the way.
T.Naturally it’s the tiny holes in the filter that these clog first .
Once these holes are filled the tiny particles will just continue circulation ..
I dont think that is correct.
When the filter becomes clogged it will not magically let particles through. It will have a reduced flow until eventually the bypass valve opens due to pressure differential - which then I accept will circulate the bits .... in the absence of a bypass filter ( which my D12s have).
...Or maybe they have different paths of pore size ,each time the oil passes some goes through the small ,some medium,some larger pores . Eventually it goes through all of them many times .
If it’s an old filter a few years old say - then because the small finer pores are clogged the smaller ( arguably equally abrasive) particles just keep passing through as the only way open are the pores too big to capture them ...
That doesn't make sense. You're saying the filter has big holes, but the small particles don't go through the big holes until all the small holes are blocked?
No
“Eventually it goes through all of them many times “
But once the smaller pores clogg up then the small agglomerations are not trapped anymore .They can get through the next up pore size ...
OK. I'll give up on this.
