Oil change? Ther must be an easier way.
rafiki_
19 Jan 2009
Stratford on Avon
I changed the oil on the 2 Cat 3126's in my Snazi yesterday. Started at 1 pm, finished at 9.30! 8.5 hours for an oil change anyone? The main problem for me was the bulk to be vacuumed out, 25 litres in each lump. It took more than 3 hours to drain the ld oil, and nearly an hour to fill. Obviously draining was slightly quicker when the oil was still hot, but after a couple of hours cooling, it was thickening up. I then had the challenge of tranferring this to a large container, which became quite a messy business, but not half as messy as filling the engines. 12 fills with my 2 litre oil can for each lump. Not much room between the engines, and getting in and out of the engine room for somebody of my size and lack of flexibility was wearing. I learnt a very important lesson with the stbd engine oil filter, wait until you have sucked out at least 6 litres before removing the filter, as is gushed black slimy stuff into my pristeen bilge! Not happy, and of course, more time to clean up!
So, any suggestions to speed up next time?
A_8
28 Aug 2005
Gothenburg
3 hours to drain the old oil seems very long, what did you use to get it out of the engine?
Mine is only 10 ltr's each but it takes around 20 minutes with a vacuum suction type thing.
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
You need a reversible electric pump permanently plumbed into the drain plug hole of each engine and gearbox and selected via valves on a manifold. You can then also refill the engines and gearboxes via the pump. A bit of work to install but the happiness next time the oils need changing makes it all worthwhile. Have a look at the Reverso system.
npf1
9 Oct 2004
Oxfordshire
I've got one of these installed. Makes it very easy http://www.x-change-r.com/. Model Model 946D - about £300+shipping and VAT. Been working very well for nearly 20 years! Only thing I've had to replace is an impeller as one gave up the ghost when I tried to pump cold oil. Propably been the most reliable thing on the whole boat!
scubaman
8 May 2006
Finland
I purchased the Volvo electric oil extractor (around 470€, iirc) and it completely changed the way I feel about the prospect of oil change. It drains about 20 litres in a couple of minutes and will of course pump the new oil into the engine as well. I have a couple of different diameter hoses for the engines, the generator and the gearboxes.
The system PCUK described would be the ultimate solution but a proper electric pump is a giant leap forward.
Latestarter1
6 Feb 2008
Somerset
+1 with knobs on!
Trundlebug
4 Jan 2007
River Trent
You don't even need to go to the trouble of having an electric pump permanently installed.
I have a small electric impeller pump mounted into a portable wooden box with a switch and a length of clear hose attached to the intake and output sides. The box has a removable lid with a handle.
Attach bulldog clips to starter solenoid for +ve and engine earth for -ve, put the output hose into an empty 25L oil drum positioned anywhere convenient.
Attach the intake to the oil drain tube, press the button and away it goes.
On my puny MD31A's with 9L each it takes about 5-10 minutes per engine.
Afterwards it can be flushed through with fresh oil and used to refill the engines by swapping the hoses round. (Note: it's slower with the new oil because it's cooler, but still OK)
My pump's like this http://www.asap-supplies.com/search/oil+change+pump/17830-0012-jabsco-pump
but others are available. It seems very expensive now, I'm sure they were only about £40 a few years ago.
The advantage of not installing it permanently is that it can be used for all sorts of other uses - pumping waste fuel, water, bilge dregs, whatever you need it for.
I've been amazed at how often I've used mine for all sorts of jobs on the boat, and how easy it makes the whole oil change process.
You could even use it for sucking out the oil you spilled into the bilge...
Self priming too.
Keep it portable and you get maximum flexibility from it.
rafiki_
19 Jan 2009
Stratford on Avon
I have a Pela vac pump, lifting out through the dipstick tube, hence hose diameter is quite small, and a lot of oil to pump.
A_8
28 Aug 2005
Gothenburg
Ok, no reason for it to take that long. I Have the same type function vac pump but a larger one that takes 11 ltrs in one go. If it takes you that long your vac pump is spending most of its time pumping air or you are not giving it enough vacuum pressure.
Having said that and realizing you have some 40 ltr's to swap every now and then I would go with the other suggestions in this thread.
jfm
Jersey/Antibes
Another +1 from me. You could install it in < 9 hours and after that oil changes are a breeze. Once you have this you'll never thing about anything else
I had Reverso (usa) on my last boat but Wasp (uk) on current one. Not much difference; both very nice. Get one with a gear pump not impeller imho
http://www.wasp-pfs.com/explore/oil-change-systems/oil-change-systems
http://reversopumps.com/oil-change-systems/oil-change-3020-medium-duty
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
Yes. It's what you pay us guys for!
Your engines have suction pumps fitted.
sunquest
31 Oct 2005
Kent
Paul, they do, but are the pumps any good?
I have two cat3116 TA's with manual pumps switchable for either gearbox or engine oil change. Only used them once when I wanted to draw off an excess litre of oil. I was shown by an ex Finnings engineer to disconnect the flexible pipe at the pump, connect a hose through an electric Jabsco pump and pump out into an empy can. Refilling was easy by reversing the pump and placing the hose into the oil filler hole. Tip, take out the oil filler cap before pumping out to reduce the vacuum effect.
rafiki_
19 Jan 2009
Stratford on Avon
Looks like the best thing to do, short of plumbing in an electric pump system, is to disconnect the hose to the internal manual pump, and use a electric pump to evacuate from there.
