MapisM
Well, of course an electric pump can make life easier.
But coming to think of it, your 3126 is very similar to my (and sunquest's) 3116. Oil capacity is also the same.
Now, I' can't recall if the manual pump is also the same, but I see no reason why they shouldn't have fitted on the 3126 a pump at least as good as in the 3116.
Mind, I'm not saying it's a great pump, not even worth considering an electric one.
But 8.5 hours is unreal!
By heart, I would have said that 1 hour per engine should be plenty, for draining.
And btw, if (as in my installation) the pumps are both on the internal side of the engine, you can actually use both at the same time, using both hands.
Are you sure they aren't partially obstructed, or anyway not working as they should for some reason?
