OB1 below the waterline?
CJ13
10 Jan 2008
I plan to replace some of my below waterline Seacocks. My ‘stock’ sealant is OB1- is this ok or should I splash out on Sika 291i ?
jwilson
22 Jul 2006
I have used OB1 on several seacocks, including one that urgently had to be replaced whilst the boat was in the water - engine intake seacock that whilst the handle turned, the ball stayed closed. Despite fitting the new seacock into a substantial spout of incoming seawater, it has stayed sealed fine several years now. At the time I thought it might hold things till I got a liftout, but it just worked as well as the other seacocks and skin fittings I used OB1 for whilst ashore, so I've left it.
Personally I prefer CT1, but OB1 is much more readily available locally, and it seems just about as good.
CJ13
10 Jan 2008
Just to be clear I propose using OB1 to seal new skin fittings to the hull as well as the seacocks.
