My port engine does not want to pull over 2000 revs the stb one is ok and goes up to the usual
2400 max. Second to last time out doing 2000 only I thought I saw some white smoke so stopped
went into reverse to see if it was a snagged prop. I then seems to work as it reved to 2400 shortly after.
However on saturday it was back to 2000 max, which suggests maybe it was'nt a snagged prop
The gauges are ok engine temp, engine oil & gearbox oil. Any suggestions.
Perkins HT6354 turbos.
"The Med is calling me"
