Graham_Wright
What do I need to do to decode the data from these and display it? (Mac of course!).
It might not be encrypted (then he might have asked for it to be decrypted) but the data is encoded - if you don’t know how, or have a bit of software to do it for you the sentences are not exactly easily human readable.We probably need a little more info on what you want to do, for a start NMEA0183 is not encrypted so no need to decode, are you thinking of seatalk which is encrypted. I use NavMonPC to display NMEA data, its old and clunky, a bit like me but works well.
I'm about to list one for sale !ShipModul do a range of multiplexers. Perhaps expensive but they work and are well supported by the company. ShipModul Marine Electronics
No version of Seatalk is encrypted but all are encoded so need decoding. They are all closed standards, as are NMEA0183 and NMEA2000 which also need decoding but not decrypting. NMEA0183 escaped into the public domain very quickly as the encoding is simple and was quickly reverse engineered. Seatalk 1 was reverse engineered by Thomas Knauf and NMEA2000 by Timo Lappalainen. As far as I am aware the Raymarine extensions to NMEA2000 which are found in SeatalkNG are still unknown but I doubt that they are encrypted.We probably need a little more info on what you want to do, for a start NMEA0183 is not encrypted so no need to decode, are you thinking of seatalk which is encrypted. I use NavMonPC to display NMEA data, its old and clunky, a bit like me but works well.
More details;-We probably need a little more info on what you want to do, for a start NMEA0183 is not encrypted so no need to decode, are you thinking of seatalk which is encrypted. I use NavMonPC to display NMEA data, its old and clunky, a bit like me but works well.
In order;-ok but where does the laptop fit in?
Why keep two AIS and GPS ? If the answer is redundancy then would it be better if they were kept on a separate “network” with the VHF and the rest were linked?
Can the E80s both connect to different devices/standards or does one need to be set as master/slave?
Which quark box did you get? What is it not doing that you want?
have you considered getting Openplotter and running on a Raspberry Pi with a Macarthur hat board on it? You need to be a bit techie, but the Macarthur hat has ports for NME0183, Seatalk and NMEA2000 and can do all the converting, plus it also has the option of a WIFI hotspot.More details;-
I have a (n old) RM GPS receiver.
Vertex Standard VHF transceiver
Two E80 plotters connected by RM "router/multiplexer
A NASA "radar" (ie AIS receiver)
A Matsutec AIS transmitter/receiver (with built in GPS)
A number of instruments all Seatalk.
I would like to connect the lot.
The vhf radio needs NMEA 0183 at 4800 baud.
The GPS outputs position either as NMEA 0183 at 4800 baud or /Seatalk.
The E80 can receive at either 4800or 38400 baud (but not both) or Seatalk.
The NASA "radar" needs NMEA 0183 (presumably at 4800 baud.
The E80 can read Seatalk, Setalkhs (= RM ethernet), and NMEA 0183 but at only 1 baud rate (4800 or 38400).
I bought a Quark "Combiner/mu;tiplexer" in the hope that it would produce workable solution.
As an engineer, I like to understand!
No!have you considered getting Openplotter and running on a Raspberry Pi with a Macarthur hat board on it? You need to be a bit techie, but the Macarthur hat has ports for NME0183, Seatalk and NMEA2000 and can do all the converting, plus it also has the option of a WIFI hotspot.
Yep it certainly doesAre you asking for laptop software to show the 0183 detail?
Pretty sure OpenCPN can do this for you.
But I’m not sure it will help the OP - he already had devices on his boat which will display the content if correctly configured… so adding another system with uncertainty about wiring, baud rates etc isn’t going to help him work out his jumble (unless i am misunderstanding his challenge).Are you asking for laptop software to show the 0183 detail?
