Night time aproach to Hayling Island Yacht Co
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
Harmony launches in Littlehampton on Monday
on Tuesday Bill and I am leaving there an hour before mid-dayish high water
arriving at chich harbour entrance at low tide and we will then head up towards Hayling Island co and get as close as we can before the light goes
we will then pick up a mooring until the tide lets us into Hayling Island Co pontoons some time before midnight
I have never been in there - not sure Bill has either
I understand withies are involved
I will be using the supertorch
any local knowledge gratefully considered
D
slipknot
28 Nov 2003
South Coast
I kept a boat there many years ago. I would recommend going in during daylight the first time. I recall quite a dog leg as you get near the pontoons, only marked by withies. Plenty of buoys to pick up further out.
Uricanejack
22 Oct 2012
Fortunately centaurs are reputed to take the ground quite well:)
A good flash light should help. Along with your patented pea stick
BarryH
31 Oct 2001
Surrey
The entrance isnt difficult but easily missed, especially in the dark. Look out for a porthand mark "Mill Rythe" If you find that then the channel into Hayling island yacht co is just after it. Look out for and ECM and a stb hand mark. That is the entrance to the channel. You wont get in at low water though. The entrance to the channel is about a meter above CD until the next stb mark. After that you have a bit more depth, not a lot though. Its fairly well marked most of the way in. The channel then sort of splits with an odd arrangement of bouys . You will need the southerly channel, you'll see all the masts anyway so will have a good idea of where to go.
dylanwinter
28 Mar 2005
Buckingham
Jolly good B
High tide is after midnight
so not expecting to get in until about 11 at best
D
BarryH
31 Oct 2001
Surrey
HW on tuesday is 1231, I would say that you should be able to get straight in if arriving there around 11. A couple of hours eitherside of HW and you should have water in the channel. Cant see you needing to hang around waiting for the tide.
bedouin
it is a rather tricky approach - best advice is to call the yard themselves and ask them where the channel is these days (it does move a bit over time). You can't head directly for the pontoon by have to take a turn around a marker post well to the left of the pontoons. Bilge keelers should be fine but there really isn't much room for error in a fin keel with a 6' draft. However the bottom is all very soft mud so you can push your way through.
IIRC there is a line of moorings that you follow to get you to the branch in the channel that leads to HYC (the left) then you head for the post mentioned above, turn round that and head for the pontoons.
Actually just googled it - check this (if it works)
https://www.google.co.uk/maps/@50.8047885,-0.9657845,527m/data=!3m1!1e3
Shows the channel clearly. They seem to have more moorings than when I was last there which makes it easier
dylanwinter
28 Mar 2005
Buckingham
and the peastick never lies
however, if I can come up with the flood then mistakes are soon forgiven by physics
and I might as well learn how Harmony behaves when invited to kiss the bottom
Dylan
PS - anyone else fancy joining for the trip?
- those with excellent local knowledge most welcome
depart Littlehampton at about 12 tuesday morning
bump into HYC pontoons at about 11.00 tuesday night
dylan.winter@virgin.net
onesea
28 Oct 2011
Solent based..
D,
Have never done the channel myself, but its time to see who else I can get to bite :D
If you have time run it with your duck punt and GPS track then set autopilot to follow the line back in :D I guess time will defeat you on that escapade. The harbor might have some waypoints to assist you, even if you do not follow them.
I am no good with Google but I think that image bedouin has posted might be dated 2014? it has clear lines where the deep bits are could be another point of assistance if you have Google earth on your phone/ tablet with GPS. Plug them into your plotter set the Autopilot to follow :D
As for use of peastick you are the expert on that and its probably the best thing to follow just remember to re-calibrate it from Harmony :D
Haven't-a-Clue
20 Feb 2007
West Sussex
Well, I seem to be off duty on Tuesday, so hoiw could I pass up the chance to sail with Dylan....I can't. Just wondering if there's any chance of a lift back to Littlehampton where the jolly green giant (my Passat) would be parked? I daresay alternative arrangements could be made.
dylanwinter
28 Mar 2005
Buckingham
I am sure cars will be moved around a bit
I could drive to HYC in the morning and drop the micra off there
maybe you could pick me up there
still looking for info on the entrance close to low tide though
Chi34
21 Oct 2010
The latest Chi bar survey showed 0.7m but that was in October and there have been storms since. Survey is on the Conservancy website.
There is a tide-gauge on the West Pole beacon.
Harbour Office are very helpful.
