gardenshed
Search for previous posts on the topic and then put together "your" spec for the sails:
Cloth Specification
Cut
Foam Luff/No Foam luff
Camber stripes?
Sail number
Leech line: Line type (spectra) & Cleat type, Velcro cover for cleat & line tail
Head/tack/clew: what type & reinforcement
Markers for 1st / 2nd / 3rd reefs
UV protection: colour & width
tell tales: No., position, telltale window?
Sail Bag
single/double/triple stitched seams?
Cross cut, tri radial?
spreader patches
Size!! 150%, 135% .....
Unless you are comparing identical specifications, the price comparisons are meaningless.
The above might appear a bit more detailed than you think necessary, but within the loft, they will have to produce a detailed build spec either for the outsourced Chinese factory or for the in-house sailmakers.
The cloth specification alone can be quite complex, particularly if you go for a "laminate". To make it easy, just ask the sailmaker to detail the materials used from one side of the sail to the other, the wieghts/thread density of the different components and if available, the laminate supplier's specification sheet. If nothing else, you will flush out the sailmaker that is really interested in getting your business.
Cloth Specification
Cut
Camber stripes?
Sail number
Sail Bag
spreader patches
