Forty_Two
Quark output default is 38,400 unless you have changed it previously.
I have….plugged in todayQuark output default is 38,400 unless you have changed it previously.
Re the nmea issues, those buffer strings look like your serial config is not set correctly on transmitter and/or receiver.In other news…..been hammering it today!
Dash finished and fully wired up. Even did some cleaning up! Only bummer is the original vhf will transmit but not receive ??? I’m sure it was working before. I was however planning on a new windlass but I got it at least make an effort. Pulls in but won’t lower the anchor. Sounds like it’s spinning but much clicking. I’ll strip it to see what’s what.
Installed the inside console. All works as expected ??? More wrap just for @BruceK
Love the little shorepower screen. All new speakers…..cockpit side panels removed for colour change. Lots going on!
All ready for Friday! ???
@vas Need your help!
I can’t get NMEA 0183 to talk to my raymarine c70 plotter for love nor money.
I’ve got a quark elec a027 that can send gps and ais over 0183. After some messing today…the p.otter would only pick stuff up at 9600 baud rate. 4800 did nothing. Any thoughts on the attached?
I can make sense of the buffer lines
wtf is that?Thanks for that! You cant change much on the quark….just the speed
It defo does AIS….got a logo with a slash through itcannot believe C70 doesn't do AIS! just googled a bit, OK, seems like it has ONE N0183 in and one out. Surely you can configure it from the interface!
also once the lot is fired up, leave it for 5-10mins to pickup some boats and start sending the data over, take some time to pick up classA ships if there are many about...
Not in yet….keep up at the back!No vids of the engines running? Was the paint job just for static display?
I can’t…..edc so need a full loom and controls etc. did try to find onerun them on the pallets not when they are in and inaccessible again!
