JAH
Active Member
Congratulations MrG - she looks great.
Well….noise is fixed ?tbh, I'd be amazed if you didn't have any issues Mr G.
good luck sorting it out
Yeah…..it has a oil separator on the other side of the engine then an open pipe (no filter can) across to the other side of the engine where the smoke / steam was coming from. I’m thinking it was more steam. Both oil coolers feel the same temperature externally. These haven’t been run at speed in a long long time. I was think blow by but no pressure at the cap and it seems constant rather than chuffing. I’m changing the lift pump but was thinking if it’s leaking internally…..that would explain lack of revs at the top end and maybe leaking diesel into the oil? Dip remained constant though. I’m going to change oil and filter on that engine again anyway just to be sure. No doubt it’s been cleaning the internals over a few hours use and worth doing.Good luck G. So the smoke was coming from the breather pipe?
Hi mate. I’m just building my confidence in her currently ???She's a corker mate. I hope you keep this one and we missed you this weekend. We're still lounging about at Trefor but will shortly move to Llandwyn if you feel up to stretching her legs.
I saw 34 knots….I think it’ll be 45 knots…..not that I’ll want to do that too oftenIt should go like the clappers when it's running properly. Got to be knocking on for 40kts or more?
I do apologise!??Would like to see a longer video when it's sorted. Impressive but was frustratingly short clip.
I've only ever seen them on the Broads lol. Can't do them any good idling all the time, in fact not sure how it's possible to keep in the speed limits at idle. Must be re-propped.
