mjcp
I have many questions! It's my 1st time arranging my own mooring (yes, the local association and an experienced diver are involved) so be gentle pls!
I've had the nod to place a new riser and mooring onto an existing grid / trot ground tackle.
Charted depth in the area is 2-5 m (TBC in the actual area when I get out there to measure later this month) and tidal range MHWS c. 5.5m. Its fairly sheltered, I've not seen more than a 1m of fetch, (but its Scotland, so could be bigger on occasions ... eek!)
Boat is ~5000kg, 33 foot with a bow roller for the mooring tackle to go over. (1m above the water line)
So questions:
What size riser chain? Length and weight.
Is the theory for swing mooring tackle based on a catenary similar to anchoring or is there an alternative theory? I assume swing room is a consideration?
Is the riser height tidal range + % or is there a more scientific formula? 7-8m has been suggested (probably assuming ~3m MLWS)
I'd also like to document the max weight on the buoy to dissuade overweight visitors who will almost certainly sneak on while I'm away. What riser chain size etc would safely support say, a max 10T "guest" ?
And then what chain (chain preferred, "just in case") weight for the buoy to boat?
M
So questions:
M
