geem
These are way betterThat's the stock photo from Nestaway's site.
FYB Marine. MotorLoc outboard motor locks for sale by mail order
That's what geem recommended in post #76. I'll take a look. My needs are for a deterrent against opportunists as the dinghy/outboard are packed and stored over longer periods.These are way better
I use a "lockbar" across the clamps as supplied by nestaway. Seems fairly substantial but any force is likely to break the plastic bits on the screw clamps.I've just renewed my insurance with N&G and since the takeover, they now want a lot more info inc serial numbers of the battery and leg.
They asked if I was using an "approved outboard lock" and didn't think there was one for the ePropulsion Spirit.
I use a steel wire with padlock or combi lock but a decent pair of snips would cut that in a second.
Should I beef up my security?
I wasn't sure about that padlock so fitted an abloy I had.
Funny thing is, as I was looking for something, I found the Nestaway product. Then realised I already had one that came with the box of boaty bits when I purchased it.
I had thought it was an adjustable table leg or similar. Didn't want to throw it away, glad I didn't and mystery object in the garage now identified!
Outboard motor clamp lock for ePropulsion Spirit & Torqeedo
The objective of an outboard lock is not to stop a thief with tools, it’s to make sure he does the minimum damage to the boat and your insurer pays out.Change the lock for something stronger. You can cut through that brass lock with a junior hacksaw in about 30 seconds.
A better solution would be the MotorLoc
Not my experience. I places where thiefs have no tools, they take the low hanging fruit.Yeah, they won't bother to cut the brass, they'll angle grind the fibreglass around it, the anchor point, or whatever looks quickest.
I have a tiny padlock which will prevent someone walking off with it unless they have a tool of some kind, but I'm hoping is little enough challenge that they won't take the angle grinder to the boat itself. I'm still not optimistic.
A hardened steel padlock is 10 times more robust than brass. I locked myself out of my boat a few years ago go when I had brass padlocks. I couldn't beleive how quickly I could cut that brass.Yeah, if they've got no tools the padlock will stop them. So, as Ylop says, the object is to stop the guys without tools whilst making it easy for the tooled up guys to get what they're taking without hacking the boat apart. Unfortunately GRP is the weak link.![]()
I don't think I've ever heard of an electric outboard being stolen out here.A hardened steel padlock is 10 times more robust than brass. I locked myself out of my boat a few years ago go when I had brass padlocks. I couldn't beleive how quickly I could cut that brass.
In the Caribbean, dinghy theft is common. It only happens from unlocked dinghies or those with easily broken padlocks. Many cruisers use large diameter chain that bolt cutters can't easily get around. They use large, strong padlocks. I have never seen an outboard cut off a rib with a junior hacksaw!
Small egg whisk outboards are not desirable in the Caribbean. Thiefs want 10 to 30hp engines as this is what cruises want to buy or fisherman use. Lots of the larger engines are bolted to transoms and too heavy to easily run away with. These boats get stolen and the engines stripped off away from prying eyes. This is where big chain and super strong padlocks come in useful.
I signed up for an early version of Litelock via Kickstarter as the owner (Neil Barron) is the B-I-L of a colleage. It is quite secure looking but was concerned a battery angle grinder could eat anything so I view it more as a deterrent. I see LPL chomped through it in 16 seconds with a hand tool.If you watch the Lock Picking Lawyer on You Tube most padlocks can be picked in seconds if you know what you are doing.
Years ago I removed a cheap padlock by hitting the body with a brick. The padlock looked good but the internals were something else.Yeah, if they've got no tools the padlock will stop them. So, as Ylop says, the object is to stop the guys without tools whilst making it easy for the tooled up guys to get what they're taking without hacking the boat apart. Unfortunately GRP is the weak link.![]()
That might be because they are as rare as hens teeth in the Caribbean. By the time you have travelled half a mile to the dinghy dock with 25kts on the nose and a 1 foot chop, you are soaking wet. We have friends who have them onboard as a back up but don't use them routinely in the CaribbeanI don't think I've ever heard of an electric outboard being stolen out here.
Might be different in the UK I suppose.
We've seen every type of outboard in use in the Caribbean. Obviously it can be very useful to have the ability to plane but there's only a handful of places where it really changes things. St Ann to Le Marin comes to mind. Horrible wet trip on a slow dinghy...
