dukeofted
Sounds like a posh trolling motor to me. Good for distances and conditions that could be rowed but you either can't or are too lazy.
I am near that level of usage for my Mariner 3.3 2 stroke. Keep us updated.I’ve put a deposit on one. My usage is probably less than 10 times a year, short trips in a 2.4m tender with my other half and the kids. The weight and noise of our current Honda 2.3 is a pain, and I use it so little the servicing is starting to get on my nerves too.![]()
Yes, please do.
The ePropulsion eLite is supplied with a 110W (output) mains (110-240V) charger as standard. The official website says 3hrs to charge from flat but that must include some "slightly optimistic rounding down" as the battery capacity is 378Wh. And as always the first and last few percent take a bit longer than the bit between 5-95%... but if you said "about 4 hours if it's nearly flat when you plug it in", that's about right. Or, "you can put about 50% back in if you take it to the pub with you and have a half decent lunch" (it's only 6.5kg and is supplied with a carry bag)!Ian of Nestaway, what about charging tines, options?
That is really helpfull. Thank you. This is a good example of someone declaring they are in business, not advertising on this forum, but helping everyone to understand the products.Just to be clear, amongst other things, we (Nestaway Boats) sell ePropulsion, Torqeedo, TEMO and ThrustMe electric outboards.
Anyway sorry I'm late to the party on this. As a couple of previous posts mention, we have actually used an ePropulsion eLite ourselves. We were also somewhat involved in the concept/development of this product, based mainly on the finding that for many (not all) yacht tender users the larger ePropulsion Spirit PLUS (and rivals such as the Torqeedo 1103) are actually more than the customer needs/wants. If you just use your tender to go to the pub and back, take the dog ashore etc, and can charge on board fairly regularly, then something that's lighter, more compact (easier to stow) and cheaper might be a better bet. And ePropulsion were not the first to think this, other manufacturers such as ThrustMe and TEMO already have offerings in the "sub 1kW" class.
The ePropulsion eLite key specifications:
- power 500W with 750W "boost mode"
- battery capacity 378Wh (integral to shaft)
- Weight shaft (inc battery) 6.5kg, plus clamp bracket (from which it's one-click removable) about 1kg
- tiller operated twist grip for power and F-N-R
- daylight visible display on top, angled so that driver can see it, showing battery capacity, current power output etc
Re power, anyone who's actually used (rather than conjectured) an electric outboard on a typical inflatable dinghy knows there's not much difference between 500W and 1000W. 500W gets it well up towards hull speed (say 4-4.5 knots, depends on boat, load etc) but 1000W isn't enough to get on the plane so increases speed by half a knot at most (whilst halving the run time). Many customers report that they typically run around at 400W-ish, as the best compromise between speed and range. So 500W is enough for a lot of people, and the eLite has 750W available if you need it. The time that boost mode is available depends on how happy the battery is (ie not too hot or cold or flat).
Re battery capacity, 378Wh was actually quite a lot for an electric outboard not that many years ago! I can remember early Torqeedo outboards with 250Wh. Anyway if you run the eLite at 378W then it will last an hour and on a typical dinghy (again, there are many factors such as load, hull shape, trim etc) that's going to be 3.5 to 4 knots. Let's be pessimistic and fill to capacity a really short and fat dinghy, you'll still get at least 3 knots, so the range is still at least 3 nautical miles. Which is quite a long way in a dinghy. More if you run it slower or on a less inefficient hull, less if you run it flat out (but it will still run for 45mins at 500W). The eLite's 378Wh is 30-40% more than its obvious rivals in the lightweight class.
Re weight at 7.5kg total the whole eLite is quite significantly lighter than a Spirit PLUS battery. The "pass up and down weight" is actually 6.5kg because the shaft removes from the clamp bracket. That is a one-handed lift for most reasonably fit adults. It is far lighter than any petrol outboard and you don't have to worry about which way up it is (there's nothing to leak out) when passing it around. It's not the lightest in the sub 1kW class but that's mainly because it has more battery than the lighter ones. It also feels very well built, they haven't cut every last corner to save weight. 6.5kg is really not very heavy.
For a lot of yacht tender users we think the ePropulsion eLite is a very good product and enough people think the same that the first batch into UK sold out before most people had even seen one.
If you want/need to undertake longer/faster journeys in your tender the eLite is probably not the right product, but there are plenty of electric outboards above it in terms of power, battery capacity, size, weight and price.
To be clear yes I am saying that 400-500W - or 0.7hp if you insist on converting it, but the conversion isn't really useful at this level because of the different (torque) delivery characteristics of petrol vs electric motors - is enough to drive most yacht tenders at harbour legal speeds, doing the jobs a very large percentage of yacht tenders do. Because it is enough. I have used one, including on the alarmingly-fast-flowing local river in January. But no it is not enough to drive your 3.5m RIB around a Caribbean anchorage at 20 knots, if that's what you need. No it won't make any progress driving your dinghy against a 7 knot tide, but nor will a 2.5hp petrol outboard unless the dinghy is so lightly loaded (ie 1 small person) that it will plane on 2.5hp.
Ian, Nestaway Boats Ltd
- Range is straightforward as explained by Ian above. We went for 35 mins at 500w and had 34% battery left at the end.
I think you would make progress albeit no danger of neck injury. Next time I’m going to try running at 350W as that should give just over an hour. I’ll aim to measure the speed of the boat too.How was the performance at say 250-300W - would you be happy using it at that level?
Is the motor a fully sealed design or is it more like the thrustme kicker (brushless outrunner which floods with water)?"no danger of neck injury"!
No... but 350W is still quite a lot more than a pair of human arms (rowing), especially when you're talking about sustaining it for over an hour, and a direct-drive electric motor turning a propeller is quite an efficient way of transferring it into forward motion. Plus with an outboard you're facing the right way, so will probably go in a straight line...
