PaulRainbow
Finally they’re doing what the Navionics app has been doing for years. I’ve never understood why the permanent chartplotters don’t have this feature.
It's been a feature of some Garmin plotters since 2016
Garmin - you can get the "garmin active captain app" then along with the navionics app, plot any routes on your phone/tablet and download to the boat.
You are missing the point .Parts availability with lugging your own spare props about the Med ( Solent )The usefulness of which I can't for the life of me understand.
Have you ever seen the test workbench used by Bosch shops for replacing/calibrating injectors and their nozzles?
You don't want to carry that around with you, trust me.
In your boots, I'd rather drill a hole in that spare and use it as a key holder.
BTW, if you think that also replacing a prop can be a DIY job (let alone with the boat in the water!), well, think again.
St Albans then Synapse. I set up an architectural model making division. They were great product model makers then got into figures for Disney approval etc.
A fantastic job but you were at the end of the design chain which meant no time and everything was to tender, they didn’t value skill and relationship. More than a few all nighters
Totally agree I have a Garmin and I cannot find a feature that allows me to hit one button and reset the course to the original course if I deviate for whatever reason from the original course. What I have to do is cancel and reset. I often also use Navionics on my iPad side by side with the Garmin. It does auto routes as well and I think is excellent and gives a good overall picture.Routes and Plotters
I consider myself to be a bit geeky so this comment is "out of character".
When we started on our current Princess, I had the latest "Glass Bridge System" that money could buy.
In fact, it is still excellent.
I spent many hours plotting routes and waypoints.
Do you know? - it is all a waste of time.
These days, I use the most useful feature that ALL plotters have - "Go To Cursor".
I simply move the cursor to the position I want to go and press "Go".
This creates a temporary waypoint that the autopilot can follow.
Of course, a passage is done in stages but if I'm using the plotter to control the auto pilot, I simply use this "Go to Cursor" method.
Yep it was great creating routes in the beginning but definitely not essential.
However, there IS one feature that I use all the time and that is to resume your track to your from current position.
Lets say you have to change course - maybe it is to avoid a ship - for us, it is usually to play with the dolphins.
When it is time to resume a route to your waypoint (temporary - go to cursor etc or from a route) you don't, necessarily, want it to drive the autopilot back to the original track.
In the Raymarine world it is called "resetting your cross track error"
Most of the time, you want it to take you directly to your next (chosen) waypoint.
I appreciate that navigating in tighter waters there are other considerations but on a longer open passage going back to the original track is silly.
A few years ago, I was helping with a delivery andI couldn't get that option to work on that version of that particular Garmin system.
The only solution I could see on that version was to stop the "Go To" and reset it - and there were too many steps.
Sorry guys, that put me off Garmin - even my old Raymarie Pathfinders from years ago had a simple "correct cross track error".
A feature that I use a lot with our Glass Bridge is the feed from the ships PC.
This gives me on the bridge a completely separate nav system using different charts and GPS etc but also provides me with a graphical log of where we have been.
Knowing where you have been in the past helps a lot when revisiting a place.
Hurricane - 100% agree on routes. In all my years of boating I have NEVER made a route and doubt I ever will. I just use goto cursor. like you. When the boat gets to the cursor, I enter the next point.Routes and Plotters
No way! If your kit is old, download the latest software/firmishwareTotally agree I have a Garmin and I cannot find a feature that allows me to hit one button and reset the course to the original course if I deviate for whatever reason from the original course. What I have to do is cancel and reset. I often also use Navionics on my iPad side by side with the Garmin. It does auto routes as well and I think is excellent and gives a good overall picture.
Hmmm. That is a standard Planus Eric, but a discontinued model called Elite. I presume that Planus must still make it for the trade, even though it isn't on website. It has visible screws but its main problem (and I guess reason was discontinued) is that the white ceramic ledge at the back of the seat hinges isn't deep enough when you add catalogue Sugatsune soft-close hinges that everyone wants these days, as in Henry's pic . When I say not deep enough, what happens is that the seat won't go past 90 degrees so won't stay up. Princess overcome this (after a fashion) with a little wooden spacer to stand the WC off the wall, as you can see in the pic. You see this throughout the Princess range. When I was noodling (unsuccessfully) a custom spec for a y85/95 my list included redesigning all this to eliminate the stand off piece, but I withdrew before we got to discussing that level of detail so I don't know whether they would have agreed the mod. It very much isn't the end of the world of course, but really Princess ought to be fitting a different model of Planus/Tecmait looks like this is a special Planus model for Princess. Your toilet with the footprint with edges and bolts is not on the Planus website. They do have a model called Match though
very nice heads; Princess does a very fine job there.
"Finally"? My 2013 Garmin boat had itFinally they’re doing what the Navionics app has been doing for years. I’ve never understood why the permanent chartplotters don’t have this feature.
I had a little play today.Toilets - how quiet are they actually? Also how quiet is the water pump, i.e. when you turn on a tap do you notice the pump? Both quite nooist on current prestige
Interesting…indeed I have seen that spacer before. Do you perhaps know why the toilet is on a pedestal? There are different height toilets available and as far as I know all the piping is in the base of the pot.Hmmm. That is a standard Planus Eric, but a discontinued model called Elite. I presume that Planus must still make it for the trade, even though it isn't on website. It has visible screws but its main problem (and I guess reason was discontinued) is that the white ceramic ledge at the back of the seat hinges isn't deep enough when you add catalogue Sugatsune soft-close hinges that everyone wants these days, as in Henry's pic . When I say not deep enough, what happens is that the seat won't go past 90 degrees so won't stay up. Princess overcome this (after a fashion) with a little wooden spacer to stand the WC off the wall, as you can see in the pic. You see this throughout the Princess range. When I was noodling (unsuccessfully) a custom spec for a y85/95 my list included redesigning all this to eliminate the stand off piece, but I withdrew before we got to discussing that level of detail so I don't know whether they would have agreed the mod. It very much isn't the end of the world of course, but really Princess ought to be fitting a different model of Planus/Tecma
Wow. I use routes all the time. I use reset XTE often.Hurricane - 100% agree on routes. In all my years of boating I have NEVER made a route and doubt I ever will. I just use goto cursor. like you. When the boat gets to the cursor, I enter the next point.
I use auto route creation to measure distances when it's not a straight line and I'm planning/contemplating a trip, but not for driving the boat.
Garmin does have reset XTE. On older firmware years ago it was harder to find (3 menus layers down iirc) which was dumb, but not nowadays. So Garmin/Raym are identical on this point nowadays.
Water pumps. The water pump is much quieter on the F55 compared to the P50 to the point where you have to strain to hear it running. Ive posted up a couple of photos of the pump set up, it's much more involved than I was expecting I assumed a single pump but as you can see there are actually 2 pumps working together. The whole lot is located in the engine room between the 2 engines. Main water tank is under the master cabin bed I believe.
Almost certainly the pedestal is there because there is the angled V hull right under that toilet, so a pedestal is the only way to do it.Interesting…indeed I have seen that spacer before. Do you perhaps know why the toilet is on a pedestal? There are different height toilets available and as far as I know all the piping is in the base of the pot.
it looks like the forum is back in full swingwe are discussing the design of a toilet
Horses for course - I'm not bothered about route ETA but that's my choice (and of course most of my big routes are straight line anywayWow. I use routes all the time. I use reset XTE often.
Route ETA is a key feature for me. On passage at D speed I will say, I want to eat at 1900 so I will open the throttles at 1730 or whatever.
On every passage I like route ETA displayed
In fact raymarine didn’t have it available in a permanent box (only a temporary pop up) I asked them to add it and they did!
I thought my dislike of Garmin was familiarity but that’s a show stopper for me.
