MapisM
Absolutely. I did say it's a no brainer, when compared to acres of MFD displays.I just couldn't see the advantage of fixed displays over the variable ones as per this set up - other than cost I guess.
My pet peeve is more vs. the (old-ish) habit of fitting just one MFD on the basis that you can get anything you want on its single screen.
Maybe it's me (though I don't think so - commercial boats are ALL configured in the same way, bar none), but I don't want displays capable of switching between several different functions, and neither a user interface allowing to do that easily.
Ideally, what I want is just enough real estate to show conveniently everything I need (which is way less than what any modern MFD is capable of, really), simultaneously, without requiring any interaction.
And pretty sure with all your displays (and their configurability), you'll be able to get that easily, without needing to tap and hold anything at all.
Which, no matter how easy, is just a side show that becomes boring after the initial wow effect, in my experience.
