Allan
After much debate, some of which was on this forum, I have decided to to change my domestic batteries. I have a start battery which is separate and charged from one side of the alternator split charger. I have a Sterling mains charger which charges start and domestic batteries but is not used very often. Most of the charging is done by the alternator and a Rutland 913. I also have a small solar panel. My plan is to fit two new leisure batteries. They will be solid wired together. I want to do away with the 1, 2, both switch. I will also fit a battery monitor.
I have some questions:
1. Which monitor should I fit?
2. What switch should I use?
3. Should I use some sort of charge relay?
Any ideas?
Allan
Any ideas?
Allan
