Needle files
petem
Cotswolds / Altea
www.fairlineownersclub.com
Has anyone tried using 'needle files' (I think that's what they are called) to clean the female ends of corroded connectors?
I have some sterndrive trim connectors that I suspect are corroded and all Volvo ever do it replace the entire switch (at £150 a pop) that is terminated with a male connector.
The Q
5 Jan 2022
Often done it as I've got lots of needles files for railway modelling. You need to re tin the connector afterwards though..
Don't bother if it's a gold plated connector though, unless you are good at gold plating..
Bilgediver
6 Jun 2001
Scotland
Yes and following the cleaning with the file carefully lubricate with a Copper Slip type grease which is available from Halfords . ONLY APPLY TO CONTACT PARTS. It is conductive.
B27
26 Jul 2023
Depending on the contact type, it may be better to squeeze them so they grip the other part better?
Filing them slacker won't help!
Refueler
13 Sep 2008
Far away from hooray henrys
On the silly twin pin plugs - I slit the pins and then prise the two halves slightly apart to force them to be tight fit into socket.
On others that you cannot do that - I have used solder to build up the pins and then file back to smooth etc - making it a better fit to socket ..
