Capn_Crusty
Hello from across the pond and please pardon my abuse of our common language.
I've just acquired a used Blake Baby head to install in my boat and I'm having difficulty disassembling it for a rebuild. I've never even seen one disassembled before so I don't know exactly how it is fastened together and I don't want to damage it. Since they're probably much more common on your side of the pond, I'm hoping someone here can give me some knowledgeable guidance.
Here's my situation. There are two bronze flanges that seal against a hollow protrusion on the outside of the bowl at the rear. One flange has a tube inlet for the fresh water and the other flange has a raised boss with a large hex head fastener in the center of it. It would appear that all I have to do is unscrew the hex head fastener and both flanges will be released from the bowl protrusion. What happens however is that the flange with the boss turns with the hex head fastener and never unscrews.
How do I remove these two flanges?
Thanks for any help that you can give me.
