Tradewinds
Wow sounds a lot simpler than my conversion.I have had this done this with new Raymarine ACU400 a couple of years ago. I sent the motor to the Hudson Marine and they basically removed the internals at the top of the Neco Motor and binned them. They then attached some cables and labeled them for me. I just connected the cables directly into the ACU 400, set it up and off we went. Hudson Marine also tested the motor first to make sure it was working okay. All the gubbins at the top of the Neco motor are not needed for the Raymarine.
Basically there are now 3 cables, paired red and black per cable, coming out the motor: Clutch, Power, Motor and the Raymarine manual tells you where to connect each to. The ACU 400 then drives the motor part and does not require any of the stuff that was on top of the motor.
Cost was not much, a couple of hours work by Hudson as it is just a test and a 3 wire tails added.
Marine Electronics UK
