billyfish
Why is there no anchor alarm ?
Yes, it uses GPS, see home page. It would be very difficult to get an accurate mobile fix on the sea (worse triangulation between base stations).Just got it going now, but is it really using gps or just mobile data
Really? Its been a feature in chart plotters I’ve owned for at least a decade… of course, designed with all the usability of any chart plotter feature - so requiring so many obscurely named menus and button presses that unless you use it every week then it’s useless.Appreciate the wish for ... but given that most dedicated plotters do not have Anchor Alarm either .... ????
Thanks for the recomendation/prompt. I'm now anchored in the office with a current position 10m away from the anchor at 144deg in the front garden. I'll be testing today and checking I get an alarm when I stray into back garden later but not when i head for the kitchen for coffee!I used Anchor Lite last season. With good success.
There's a problem with Android turning GPS access off when an app is in the background, which the author warns about. If I recall correctly, shouldn't be a problem if you set 'never to to sleep while charging' on the phone, and plug in to a power supply.
I think the pro version allows two paired phones (one on the boat, one with you) to give a remote function. I haven't used the latest version, which should be an update after Google wanted more explicit warnings about apps which track location (which this obviously does).
I also use the Anchor Watch Pro version and it works very well.Thanks for the recomendation/prompt. I'm now anchored in the office with a current position 10m away from the anchor at 144deg in the front garden. I'll be testing today and checking I get an alarm when I stray into back garden later but not when i head for the kitchen for coffee!
(went for the paid Pro version after a brief view of Lite as it looked good enough to brave a fiver)
Don't forget to set a more sensitive sector so you don't bump into the coffee table!Thanks for the recomendation/prompt. I'm now anchored in the office with a current position 10m away from the anchor at 144deg in the front garden. I'll be testing today and checking I get an alarm when I stray into back garden later but not when i head for the kitchen for coffee!
The Raymarine Axiom has an anchor alarm, but it's attached to the 'wizard' which calculates scope etc. and requires you to ping your position when you drop the anchor. Answers on a postcard please for how this is impractical and inaccurate. (I'll start the ball rolling - where did the anchor end up when it actually bit and held?)Appreciate the wish for ... but given that most dedicated plotters do not have Anchor Alarm either .... ????
Anchor Lite is free ... as are various other ...
It’s not a silly question at all, because whilst that’s obviously what you want the operating system does clever stuff to save battery etc. for developers android phones are all slightly different so even more complicated… and different versions of OS add new features that can break thinks the worked before.Silly question really, but do these phone anchor apps keep going with screen on phone off at night? I’ve always assumed they do but never actually checked.
from memory pretty sure the screen will turn off but the gps keep receiving position which uses a bit of power, best to keep it plugged in.Silly question really, but do these phone anchor apps keep going with screen on phone off at night? I’ve always assumed they do but never actually checked.
The Anchor Watch Pro that I use on an android tablet does keep working and monitoring when the screen is off and at night.Silly question really, but do these phone anchor apps keep going with screen on phone off at night? I’ve always assumed they do but never actually checked.
