squidge
As Requested i now have the information regarding the replacement skin fitting for a Nasa log.
Ask for an Aquafax bronze 1-1/4 fitting part number 2-70254
if your local swindlery cannot supply then TCS Chandlery will post
01375 374702 or 01702444423
it will cost you around £18 +p&p
you will need to clean up the inside bore and remove the tabs as this needs to be smooth to accept the nasa log, i did this with a dremmel type multi tool in about 10min . Once clean it will need to be trimmed down in length to match the plastic one . i used the plastic nut on the bronze thread as a guide and used a hack saw and file to produce a flat level surface for the log to screw down on.
Bond it to you hull with whatever you want and sleep a little more soundly knowing you have something a little more substantial that a bit of plactic keeping you pride and joy afloat.
I hope this helps
regards
Squidge /forums/images/graemlins/grin.gif
I hope this helps
regards
