oldbloke
Sorry, its a quote. The "agreeing" is the main bit.
That sounds like an unnecesary faff. If you think it is correct way to go then so beit. But look around you when sailing & see how many others adopt that idea of rolling the sail bag up under the boom..Also with the loose footed sail, when a few gusts of wind filled the sail with the lazy jacks loose and the sail bag hanging down under the boom
The sail bag will be rolled up and held that way whilst under sail to stop it flapping. As a result this make it a whole lot easier to raise the main in future by not having to keep dead on into the wind without the battens catching on the lazy jacks.
Try & keep up. Have you not read the OP's post #43?The more I read this .. the more I think the lower slide / slug is catching ....
The title says that luff is tight but bottom 1m of sail is baggy ... even with overtight mainsheets / leech ... the luff should be slack in entire height ... not just in the last 1m at bottom.
This says to me that that slug at 1m is jamming ??
I would test this by removing the last 1 or 2 slugs from the mast groove at bottom of Luff ... then hoist and see what happens. If sail hoists fully and Luff is tensioned all way - then its lower slug that is at fault.
We all do itNo I hadn't actually ... tks for pointing to it ..
