Always found my mainsails set better with at least one reef
Yea it has a black slider that fits inside the boom.Is the clew attached to the boom track by something, other than the wirerope, thimble and schackle visible in the first photo?
There is a black structure obscured by the webbing, is this a slide?
It does only seem an issue when the wind is very light. Applying a bit of topping lift makes the sail shape almost totally collapseNot to state the obvious or anything but boom will rise a bit once sail is powered up. Can you apply just a bit of topping lift just to get boom off sprayhood whilst sail is ‘depowered’ without scandalising the sail?
Do you have a rigid vang or kicking strap?
I have a similar looking boom (Seldén, early 80s), on this the outhaul (wire rope with thimble) attaches to a car that runs inside the track which has a holed tab up the slot for the shackle. Difficult to know for sure, but I get the impression the black slider increases the distance between sail and boom by 10mm or so, compared to what I believe was the original idea.Yea it has a black slider that fits inside the boom.
My new sail is loose footed but the old one had a bolt rope, and never had issues with it hitting the spray hood. I think for now I will go back to stretching the attachment to the mast as shown in the pic.
Seems like a pretty basic requirement that a new sail doesn't leave you with the boom rattling off the spray hood; get the sailmaker to sort it out.Is this a brand new sail? Talking to the sail maker would be the best thing.
I'm confused - it sounds like you're raising the sail with the kicker tensioned?? I'm sure I must be misreading that?My older boat - boom touches sprayhood when main is hauled up tight - when kicking strap is not released .... if I release that - I can get another small bit on halyard and boom is then clear of sprayhood.
????? yours ????
Correct And I removed rhe original slider and modified the thimble to allow the sail to be pulled very tight if needed.I have a similar looking boom (Seldén, early 80s), on this the outhaul (wire rope with thimble) attaches to a car that runs inside the track which has a holed tab up the slot for the shackle. Difficult to know for sure, but I get the impression the black slider increases the distance between sail and boom by 10mm or so, compared to what I believe was the original idea.
Just a suggestion to check everything is free for hoisting. On ours it’s the mainsheet that is occasionally forgotten. I am reminded when I can’t winch the black mark out of the clutch. Our halyard being marked for full up, and each reef.I'm confused - it sounds like you're raising the sail with the kicker tensioned?? I'm sure I must be misreading that?
My mast has new pulleys fitted last year, and the sail can be pulled tight easily.. Kicking strap is loose. I will contact the sail maker as the ssil is not even 12 months old. I can pull the foot of the sail very tight and also raise it tight, but still it seems to drop too low.I don't think I am different to many out there - who tends to not adjust kicker that often.
I and I am sure many others arrive at a reasonable kicker that does its job without being too restrictive.
2+2 does not = 5 .... ok ?
My comment was based on occasionally having tensioned kicker on a previous outing ... forgotten to slack back to usual ... raised sail next time .... and found boom slightly lower.
Another factor that can do it ... raising sail while sail is trying to do its job ... the halyard then has difficulty getting that last few cms up ... luff up and viola - sail up, boom up ... all good to go.
