My Ideal Liveaboard Yacht -Offer Accepted - Champagne on Ice!!
silver-fox
3 Apr 2006
Sicily
yacht.silverfox.googlepages.com
Well we have finally put down a deposit on our chosen liveaboard boat. In an earlier post I was asked to post what our choice was, and the criteria once the decision was made. So here goes.....
Firstly can SWMBO and myself thank you all for your advice, good wishes and encouragement - very heartening!
Well the deed is done, the deposit lodged with the broker and the survey booked for next Wednesday. Unless something 'orrible turns up we should be proud owners before Christmas.
So what did we go for in the end? To my surprise and delight a British boat, the Moody 425 no less, won the day.
What are our selection criteria? Well, in the end we decided the following were important to us: -
1. Capital cost below £100k, (much less if possible!!)
2. Fibreglass for low maintenance
3. Proven, stable and seaworthy (decent keel/ballast, stable, small windows, moderate size cockpit etc)
4. Reasonably fast for good passage times (lWL and fin and skeg were factors here)
5. Roller reefing main and foresail to encourage us to reef early and often and in safety from the cockpit
6. Sloop rather than ketch as the roller reefing gives great variety of sail plans without all the extra mast and rigging
7. Large enough to live on comfortably and have guests from time to time but not so large costs went into the stratosphere. In the end we decided 40ft min and 45ft max.
8. Good storage
9. Decent size saloon with straight bench seats that could double as bunks or for just plain slobbing about on.
10. Spacious aft cabin with centreline bunk (important to us this for living aboard)
11. Good sized galley with plenty of cool storage
12. Good engine access (3 sides)
13. Marinised Ford diesel (by Thornycroft) so parts cheap and readily available.
14. No teak decking (gets too hot and too expensive says Nigel Calder and who am I to argue?)
15. Clear uncluttered decks with area for SWMBO to sunbathe
16. Plenty of opening hatches for ventilation
The Moody was unique in hitting all these marks for the money and size (Along with its sister yachts the M38, M422, and M44). Other yachts we saw seriously tempted us, but in the end the M425 is the boat for us.
Do we see any inherent disadvantages in our choice? The answer has to be yes. Firstly, by modern standards, the heads aren’t as big as they could be and a few inches here and there would improve things considerably.
More importantly we are aware that with a centre-cockpit design there are constraints on the Bimini height and this is going to be a bit lower than we ideally like. Also the centre cockpit can make mooring stern-to a bit more difficult (– but at least you get a bit more privacy once moored.)
Was it an easy choice to make? In theory yes, the boat model selected itself on merit over a period of a few months and many viewings. In practice it got difficult when we narrowed our choice down to the final three 425s – all of which had pros and cons. I have to admit that the bottom lip was wobbling when it came to final decision time. That said, having had a few days to think about it, the decision is sitting well with us both so we are happy now.
So as previously mentioned, the house is sold and we have just 3 months to get everything ship-shape and Bristol fashion before becoming full time liveaboards.
Excitin innit?/forums/images/graemlins/cool.gif
…..Expect future posting to change in tone as I start to worry less about boat choice and more about gear and maintenance.
Anybody make a recommendation on what anchor I should buy?/forums/images/graemlins/wink.gif
Anchoring always generates a good thread with lots of ideas.
At least two anchors and cables each capable of holding the boat in the worst conditions you can imagine in your most pessimistic frame of mind - then a couple of lighter ones with cables for lunch stops etc.
A range of different types to cope with the times when one holds and the other drags. I like the genuine Bruce, but only at 15kg plus. (Not the various others such as Claw which originally had slightly different geometry to avoid infringing patent). My last boat was 42 ft but with a lot less windage than yours. Very happy with a 30kg bruce on 30 fms (say 60 metres) of 3/8 inch (about 9.5 mm) chain. Other anchors were in the 20 kg range with chain and nylon cables. Up to F7 in a sheltered anchorage, the 30kg Bruce. F7 - F9, added a second anchor and cable, usually 20 kg Bruce. Gusting over F 9, third anchor and cable laid - 20 kg Danforth.
My current boat is a lot lighter and I have a 16 kg Oceane as main anchor which is very good digging in even quicker than the Bruce and with a big fluke area, but you will need something a lot bigger / heavier for a main anchor which means its more expensive cousin, the Spade.
Have a look at the recent YM, I think its still the current issue, with comparative tests of about 20 types of anchor. A number of the new designs look very interesting and generate high holding power.
Good ground tackle mean contented nights sleep at anchor. Its worth going up a size for peace of mind and a quiet nights sleep.
Well Done... much the same criteria as I used, other than budget and saloon bench seats, (would have prefered them, but with two sets of double bunks, it works OK). I actually find that teak is cooler than GRP on the feet???
Doesnt it come with an anchor?
You are correct about gear and maintenance. Easy to change the impellor, but a bug*er to change the cambelt.. I got somebody to do it for me.
I understand that the 425 is very similar to the 44, so any queries, and a few of us will have been there before.
I'm sure you will have found the Moody Owners site... but if not:
http://www.moodyowners.org.uk/
http://www.moa.myzen.co.uk/cgi-bin/discus/discus.cgi
worth joining for £20p.a.
Richard
Congratulations!
We have a Moody 38, our story of liveaboard life is here .
As regards to maintanence as long as you remember "Cruising is fixing boats in exotic places" you'll be fine. Mind you, our Moody has required little attention so far.
Here is a list of things I added that I would not be without:
Echopilot bronze forward looking echo sounder
Icom VHF with cockpit command mic
Hydrovane
Plus the usual Bimini, solar etc. but those three made a huge difference.
Moodys are great. I was on one this summer for two months. Fantastic boat. Very comfortable. Stable. Loved it. Will miss all it's mod-cons when I get to my brick.
Congrats- champagne on ice indeed- but cork not popped 'till after survey yeah? I'm in a similar position- offer accepted on a Moody as well (tho' smaller, not intended for liveaboard- yet!). Survey on Monday... trying not to get tooo excited just in case....failing miserably!
What's a survey?
It's where a guy comes round your house and checks all the bricks and mortar, you know, to see if it needs re-pointing. /forums/images/graemlins/wink.gif
Exactly the same as my sentiments except my survey is Wednesday!
Can I say thanks to one and all for the encouragement and advice. Its been appreciated and very, very helpful
Jonic,
why did the Echopilot bronze forward looking echo sounder become so usefull, on a 35' boat?
Just interested!
poter.
Hi Poter
We cruised the Bahamas and were able to take very narrow cuts between the deep water and the banks. Also travelled from Florida to Washington on the inland waterways and through the French canals to the Med. The Echopilot gives up to 100mtrs ahead plus depth below in real time. Most conventional sounders are up to 15sec delayed. It's also great for picking an anchoring spot in a shelving anchorage. When we changed to the 38' it was the first bit of kit I ordered.
Details and information here
okeedokey makes a lot of sense.
Nice to have but I am sailing in the western med. at the moment.
I have to buy other bits, as you can appreciate on a 30 year old boat, lots of bits to do, my priority is new instruments so maybe just maybe! at the LBS there maybe some deals.
Thanks for the info.
poter
poter
I'll be on the Dufour stand at Libs again so come and say hi. Where in western med are you?
