vic008
For say half inch bolt. Thanks
I've found Nyloc nuts work well.using a locking nut
They are OK, but all keel bolts use a locking nut. Why? It is the most secure way to put pressure on the bolt thread to stop a nut coming undone.I've found Nyloc nuts work well.
I don't disagree, I use double nuts on my engine mounts, the second one is a NylocThey are OK, but all keel bolts use a locking nut. Why? It is the most secure way to put pressure on the bolt thread to stop a nut coming undone.
We don't know the application but simplistically use red Loctite for a permanent fixture and blue for one where there will be regular need to release (and in the latter case use fresh Loctite for each release).Loctite. But check the grade first as there are many applications.
but as suggested above. Can one really beat a castellated nut?
even gives a degree of visual indication of possible failure
Slotted or castellated nut?
Unless you are wanting to keep the height of the bolt to a minimum, I would always suggest using a locking nut rather than any washer.
Assuming no nut:-For say half inch bolt. Thanks
Some mention Loctite / threadlock - personally I am not a great fan of such on a boat unless its only solution such as when thin nut on short bolt. I much prefer a mechanical solution.
What is this 1/2" bolt part of?For say half inch bolt. Thanks
The quote, in Nevil Shute's Trustee from the Toolroom, is: "An engineer is a man who can do for five bob what any bloody fool can do for a quid". But he also says - origin unknown, so presumably he did not coin itAs somebody (Neville Shute?) once remarked: "An engineer is a man (or woman nowadays) who can do for a shilling what any fool can do for a pound," (Or something like that )
That’s how I’d always done it until I read the article I quoted earlier. Half nut first is demonstrably even more secure.On my 16mm engine mount studs I use half nuts on top of the standard nuts. Rock solid locked off
