More on gas fittings.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
From a previous thread ...
... a Hayward 4005. But surely it is neater to get a hose with an M20 fitting already crimped on? ...
It seems that ready made hoses to do what I need are scarce, but I've managed to source the fittings for the gas bottle end.
The next obstacle to overcome is the bulkhead compression elbow joining the gas pipe to the cooker hose:
This has obviously been made up of different parts, and needs to be replaced. Any suggestions?
Tranona
10 Nov 2007
That fitting is really rubbish and is metric. I was unable to find a replacement. I had all that replaced on mine with standard fittings. Will look on the boat tomorrow to see how the fitter did it.
Tranona
10 Nov 2007
Just looked at mine. It uses the elbow fitting and a straight adaptor as shown on p62 of the BES cartalogue. These are brass rather than the (rusty) mild steel of the original and use standard olives in the compression fittings.
20 Jun 2007
Tranona
10 Nov 2007
You mean 11690 for the straight? I can't see a BSP to compression elbow on that page, my catalogue is September 2013.
[Later] Also looked online.
The elbow is 11696. The male end of the straight connector goes through the sheet steel and the elbow screws to it like a bulkhead fitting. Gives you a compression fitting at either end.
20 Jun 2007
The [BES] elbow is 11696. The male end of the straight connector [11690?] goes through the sheet steel and the elbow screws to it like a bulkhead fitting. Gives you a compression fitting at either end.
Only just seen this reply. Thank you, but I still don't get it.
I'm really struggling with this. I would have thought that turning 90° via a bulkhead with 8mm pipe would be a common thing to do, but I can't find the fittings anywhere. I've even resorted to asking the suppliers and manufacturers.
Tranona
10 Nov 2007
Well, it works on my boat which is exactly the same original fitting as yours. The fixed pipe behind the splash shield has a right angle bend in it so that it goes straight into the in line fitting.
Like you, I was puzzled by that horrible steel fitting as it seems the bore is larger than the olives for the pipe on the new hose. So that is the point at which I got a fitter in to do the job and replace the entire system.
Tranona
10 Nov 2007
Nonsense.I've got a mild steel elbow on my gas cooker that is probably thirty years old.That is just unnecessary scare mongering.
The one in the picture is standard fitting on Bavaria and as you can see corrodes to the point that it is almost impossible to undo. Not surprisingly I replaced mine with brass fittings after less than 10 years internal use. The similar bulkhead fitting in the external locker had to be cut out as it was so corroded.
1 Aug 2011
Maybe in a boat next to you?
I'd be more worried that it was only held on by two or three threads & I'm not keen on brass because it age hardens & can become brittle.At least with rust you can see it!
