Karnic
Hi
What type of rope/lines to use as a permanent mooring to a 19 ft boat is recommended. I leave boat moored to a concrete block in harbor but sometimes to quite strong Northern easterly winds. At the moment im mooring boat to a main cleat and apart from the main it is also tied to 4 other cleats ( 2 bow port/starboard and 2 stern port/starboard). My experience in this field is rather limited and i would like your help re which is the best material, as at the moment i am facing a dilemma because every time i want to untie/tie boat to mooring i am struggling lots to remove the rope from the cleat. Pictures of material of rope and cleats im using are similar to the attached. When i thimble the rope it is nearly impossible to pass from the hole of the cleat in order to make knot. i manage but its a lot of a struggle and was wandering if some sort of mooring rope that is strong and easily flexible in order to handle better. What are your views and could you help please?
