Gypsy
A few days ago we entered a small port on the Nth coast of Crete and were allocated a berth alongside a solid concrete jetty. We are in a Ben 473, later a Bav 47 was berthed behind us, 20m back towards the entrance of the marina. Similar sized boats but we are probably heavier as we are loaded for cruising whereas the Bav was a charter boat..
The first night was fine, then the weather changed and Nth winds developed waves of 1m+ outside and a swell came into the marina of around 30-40cms during the following night.
I had a bow line and stern line and 2 springs with plenty of fenders against the wall which also had car tires, however the incoming swell caused the boat to range along the jetty to the extent of the slackness of the lines and their elasticity and therefore there was a huge shock onto the cleats and ropes when the boat reached the extent of its 'harness'. I tried different combinations of tension and ensured all ropes were taking the strain as equally as I could but kept having visions of the cleats ripping out, or if I tensioned the lines to much the hull being forced against the fenders and eventually popping them.
Meanwhile the Bav behind me had only a stern line, fairly short to the shore bollard and a bow line, both quite tight holding the boat to the jetty with virtually no ranging but it 'cork-screwed' terribly as the swell swept past.
As soon as I could, I moved into the marina about 50m and took a stern to the wall mooring which meant the swell came to us side-on. The boat rolled a lot but there was no threat to the cleats. We changed our sleep style by 90deg and slept well.
So, forum experts, what can you advise about the best way to tie up in the circumstances I have described?
We didn't sustain any damage and I don't think the Bav did either, but it a good testament to the Bav cleats that they held on for another night after we moved.
