Moderately good idea for "outies"
tcm
11 Jan 2002
Caribbean at the moment
Moderately good idea for \"outies\"
I took the paddlewhel log out of the boat whislt it was on hard standing. From a little test using the smoke from a cigarette, it was clear that the colder/damper air in the bottom of the boat rushed out through this hole for quite some time.
or perhaps this is a standard thing to do, dunno?
Ohdrat
8 Mar 2002
h
Re: Moderately good idea for \"outies\"
hope you remember to put a bung in it come lift in ;)
jimi
19 Dec 2001
St Neots
Did you try tipping the boat up a bit so it completely emptied of air? Another problem may be the syponing of cold air from the upper atmosphere through the craft causing local climatic anomalies.
wiggy
13 Jun 2001
Portsmouth Harbour
I would be concerned that if the air rushes out too fast if may from a vortex under your boat that could eventually grow into a tornado so large that it sucks your boat and all surrounding craft in never to be seen again, it really can happen, I'm sure I saw it on the telly!!!
tugboat
1 May 2004
Devon
It's actually the warmer air higher up that holds more moisture. If you let out the colder drier air the relative humidity in the cabin will increase until small clouds form under the deckhead. If allowed to continue, it will rain inside your boat and soak your upholstery etc. Still at least there's a hole in the bottom to let all the water out. /forums/images/icons/crazy.gif
Ohdrat
8 Mar 2002
h
Freezing fog is even worse..
longjohnsilver
30 May 2001
Oh dear tcm, not back on the fags again?! ;-)) Cigar smoke would have been much more effective.
tugboat
1 May 2004
Devon
Suffered? SUFFERED? We haven't started yet! Wait till that Caledonian lot get going! /forums/images/icons/shocked.gif
Cobra
4 Jan 2002
Brightlingsea but boat in Wivenhoe
abode-mortgages.co.uk
I trust...
...that you are aware of the potential climatic changes that you could be bringing on the microcosm beneath your boat? You have I hope seen the film 'The day after tomorrow'??
<hr width=100% size=1>When God invented time he didn't give me enough of it.
tugboat
1 May 2004
Devon
There's never a Caledonian around when you want one! /forums/images/icons/frown.gif
