Wiggo
Genuine question
Given that it is not possible in the Solent to leave sufficient room for wash to die away completely, and given that dropping from 20 to 10 knots will leave a vastly bigger wash, which gives the most comfortable ride for a yacht:
a) overtaking you and remaining on a parallel track so you have to cross my wash at a gentle (30 degree-ish) angle, or
b) overtaking you and then turning sharply across your bow (a good distance away), so you cross my wash at right angles, but it's quite wide at that point, or
c) overtaking you and turning sharply across your bow as close as is safe, so you cross a very narrow wake at right angles?
I imagine that a) will make you corkscrew violently, b) will make you pitch quite a lot, and c) will make you pitch much less, but may frighten the living daylights out of you if you think I don't know what I'm doing.
Happy to modify my behaviour if it helps make life more comfortable...
<hr width=100% size=1><A target="_blank" HREF=http://homepage.ntlworld.com/graham.wignall/boats/eulimene600x800.jpg>The old and the new</A>
