Jenko
Still waiting on delivery of my new boat.........
I was checking out the spec for the engine it comes with a merc 75, interestingly enough I noticed the 90 is the same weight, size, capacity, compression ratio, stroke, etc, etc, the only difference is the max rpm (on the 75 its 4500-5000, on the 90 its 6000).
So, obviously Mercury are just rev limiting the 75.....Question is How??. Is it done via ECU, or a turn screw on the carbs?, also, would the torque curve be different on both engines at the lower end of the rev range.
Cheers.
Paul.
P.S. The 90hp was a £1000 optional extra!!!!
Cheers.
Paul.
