D
Deleted User YDKXO
Back in January when I first got my boat in Mallorca, it achieved a flat out speed of 31.5 knots (GPS measured). By May the boat had been moved to the Cote d'Azur and the max speed had dropped to 26 knots with a 300-400 rpm reduction in max rpm. I arranged for a diver to clean the hull and I can see that that he has removed most of the fouling from the hull although the sterngear is not absolutely clean. Dissapointingly, the max speed has not increased after the hull cleaning which leaves me a bit puzzled
Question for Medxperts. Does increasing water/air temperature affect boat speed? Or, is it still likely to be due to hull fouling or some other mechanical problem?
