Tranona
The extra 1" diameter would change revs by around 250, so a 14*9 should enable you to achieve 2500 and cruise at under 2000. However it will only give you about 0.5 of a knot of extra speed in flat water.
I must have been in a very good mood that day....
thanks all guys for the interest.The extra 1" diameter would change revs by around 250, so a 14*9 should enable you to achieve 2500 and cruise at under 2000. However it will only give you about 0.5 of a knot of extra speed in flat water.
I very much doubt you can attain 6.5 kts, what is her LWLthanks all guys for the interest.
However the issue is not that i am lacking half a knot or so.
With this config i should reach one way or another apprx 6,5 knts. I can barely get more than 5. I checked also here http://www.vicprop.com/displacement_size.php?action=calculate and the overall setup ( power, prop size, gear ratio) should bring me to more than 6 knts easily. Boat is just out from the yard, so polished !! just wondering.......
Your calculator suggested a 14.8*8.8, but your 15*19
Hey its not 15x19 of course!! that would be steep indeed. I have 15x9 which is actualy close to the proposal above.
But yes you are right I made some calculations with propcalc and come also to 5.7 knts.
Ok in that case i have to use my sails a bit more to be faster.......
That is more realisticNow i found an old test from some swedish magazine where the theoretical speed for the md7a setup has been defined to 5,8 knts.
vasant, how are you measuring the speed? .
