jonathanhsm
The bottom of my steel mast compression post is badly corroded. See pix. It had been sitting in bilge water for months/years, and while I had fixed the leak so the area is dry ages ago, I only papered over the rust with anti-rust paint etc.
Now during lockdown maintenance I have finally chipped away at the rust which inevitably came away in great slices.
There is still solid metal left although it is perforated in a couple of places. So without major or expensive surgery I am wondering how I can support the support.
Possible options :
Get it welded .. but it’s a tight space and surrounded by fibreglass and welding expensive ?
Build a small dam and surround the base with concrete…or resin
Fill the hollow post up through the perforation holes with maybe builders polyester resin for filling concrete or epoxy. Then glass around it.
Bolt wooden blocks sitting on bilge floor to each side of it – to take the strain.
Any combination of the above … or any other suggestions welcome.
The mast truss it is sitting on appears to be OK – I chipped a hole through the fibreglass and the metal is showing grey rather than brown !
I will have to cut away the woodwork/bulkhead from the rear of the post to get at the inevitable rust on the rearside.
As I say all suggestions welcome.
NB boat is a 30+ year old 27 foot fibreglass sloop with deck stepped mast sitting on metal support
Possible options :
